Sony BDV-N7200W software issue - please help
RasmusEU
Hi.
I bought Sony's BDV-N7200W yesterday - it was my first sound system. Everything went smooth when setting it up and connecting the wires. However after I updated the receiver / blu-ray player, it shut itself off. I turned it on again, but this time there was no sound, the eject function wasn't responding and I couldn't get to blu-ray main menu. It seems to be stuck on the: ''Blu-Ray Disc'' screen. I'm using HDMI ARC.
Please help.
*Sorry for any incorrect english*
Anonymous
Not applicable
Hi there
Your English is fine :slight_smile:
On the N7200W unit itself, press and hold the "Play" and "Eject" buttons together for more than 5 seconds.  Remove any disc that is in the player.  Then disconnect the power cord from the mains socket - leave for about 15 minutes - then reconnect.
Hopefully this sorts out your issues.
3 REPLIES 3
Anonymous
Not applicable
Hi there
RasmusEU
Thank you for your reply.
Before I saw your reply, I went to the store where I bought it and got it replaced. Sony told me there were data corruption, when I interfered the update by manually turning it on again. But I will remember what you said!
Cheers!
7200ww
HI,
IV,E HAD JUST THE SAME PROBLEM
ALL SO WHEN I SWITCN ON THE T.V. THE SONY SCREAMS IT,S LITTLE HEAD OFF
K.R
