KDL-HX85x not recognizing USB stick
MoleUK
There is a neighbour up the road with this particular model of TV and i'm trying to get his TV to play video from the usb stick. Usually this is a simple process, but his particular model doesn't appear to recognise that the usb stick is plugged in at all.
Is there something specific I need to do to get it to recognize the USB stick, or is there a chance there is a compatability problem going on? The same stick worked fine in the other TV in his house (panasonic).
1 REPLY 1
Anonymous
Not applicable
Hi there
Format the USB Drive using FAT32 File system. Im assuming its formatted as NTFS.
See Notes here: http://pdf.crse.com/manuals/AE7H100511/ENG/usb_europe_ga_twn.html
