16mm manual mode not possible
MichaelWalter
In the camera i can't switch to manual modus with the wide and 2x cam. Anyone else experienced this?
profile.country.NL.title
Strampke
From the manual:
Hint
You can also switch between cameras by swiping down the camera screen.
To use the zoom
Pinch in or out on the camera screen.
Use the volume key.
Tap (Switch angle button) repeatedly to select x1 (normal) or x2 (2x opticalzoom).
Drag (Switch angle button) to the left and right.
Note
Zooming is only available for the main camera.
Switching angles using (Switch angle button) is not available when the manual mode is selected
1 REPLY 1
Strampke
From the manual:
Hint
To use the zoom
Use the volume key.
Note
