Hello, recently I have bought a headphones B&W PX7 S2. There is a possibility to listen via APTX Adaptive or via cable, USB-C direct connection. When I use a cable conection throught USB-C cable, sound volume is really low, actually twice lower than over bluetooth. Is there any fix already for that ?
Sony Xperia 1 V
B&W PX7 S2
Hey Damian87, before I suggest anything else, the headphones' USB is for charging, not headphones, so it won't be guaranteed that it will work.
Having said that, try a software repair, it's described here:
B&W px 7 s2 and px8 series headphones using usb-c for music listening in order to transmit lossless quality of audio. Once you are listening via usb-c, you are not loosing data packages as in case of Bluetooth.
