Xperia 5 😓😣 problems
cccbadr
The previous update was excellent I liked the phone, it was satisfactory performance even battery, with the last update and the first was weak with Time became good but not like the previous I wish from the team speed up the device while maintaining the battery and stability in the system and thanks for the efforts switched
 Weee neeed thaat :
* stability of software and hardware
* smouth performance
* Good battery life during
1 REPLY 1
profile.country.PH.title
MarlonUk1
Hello @cccbadr
It would help to routinely factory reset your device once at least 1 or 2 years of owning your device. Try to review your apps , see if you have apps that you no longer need. And there are other helpful tips in settings-support
