A290 Built-in Flash still triggers with hotshoe attached
SamShoots
Hi everyone,
I've just purchased a Neewer Speedlite TT560 and a hotshoe adapter for my (archaic) Alpha A290. I was under the impression that with the Speedlite attached, the built-in flash wouldn't be activated, but it still attempts to pop up and hits the hotshoe adapter.
Is this correct? Or am I missing a setting I need to adjust on the camera itself? I've checked the manual but I have failed to spot anything.
Any help would be greatly appreciated!
Thanks, Sam
1 REPLY 1
jumpsuit
Hi @SamShoots and welcome to the Community :slight_smile:
That doesn't sound right.
Sorry to ask but is the hotshoe adapter / flash fitted properly?
I've checked the manual for the A290 and the only mention of
changing a flash setting is for wireless flash shooting, where it then tells you to take the flash off 😞
