A58 uploading RAW images
tosimmo94
I have Elements 9, which is fine for what I need. But A58 images don't seem to upload into the camera RAW in Elements 9, and I've had to install the 'Image Data Converter' software from Sony. But then the uploaded files don't seem to be recognised by Elements; I can do some editing in the Image Data Converter application but then save only as jpeg. I know there is probably a simple solution, but I'm not at all savvy with IT stuff! Any (gentle) suggestions welcome! And many thanks in advance.   Tom
1 REPLY 1
mischof67
I have recently had a problem with my A99. Are you using a PC or a Mac?
