A7II Touchless Shutter Easy Workaround
JamieBrady12
Hi Everybody,
For two nights I struggled to get the Touchless Shutter App to download onto my laptop. I found that there are, or have been, so many people struggling to download this app and get it onto their camera. Just hours wasted trying to get an app working to load a feature that should already be installed on the camera in the first place.
I was amazed to find that it is actually possible to download the App using the App feature on the A7II. It took me about 3 minutes to get the App installed and running. One must be connected to the internet but it is fairly straightforward,
This realy should be made clear on the Play Memories webpage.
Anyway, I just wanted to share that with you in case somebody having a hard time like I did needs a bit of help.
1 REPLY 1
jumpsuit
Hi @JamieBrady12 and welcome to the Community :slight_smile:
Yes, there have been some problems reported with purchasing / installing apps
so thanks for sharing your tip!
