Hello,
I have some questions about the new A99 before I buy.
1) Does camera support 90 MB/s write speed Ultra High Speed (UHS-I) bus architecture
2) does it support HDR remote control?
3) Does it have external cable support for intervalometer to enable MX2 control from Dynamic Perception?
4) does it support wifi Direct? Use Case Scenario; Preparing my camera with shootingscene last photocheck. a) take picture, camera sents to tablet, I check my picture on tablet to see result and adjust accordingly
Thank you for your reply,
Dear HowLiu
Welcome to the Dutch Sony forums. Please note that this is a Dutch language forum and it will be easier for users to respond to you if you post your message in Dutch. For questions in the English language please access the English forums by clicking the language selection option at the top right of your screen, next to the Sony logo.
Kind regards,
-Tycho-
Beste HowLiu
Hartelijk welkom op de Nederlandstalige Sony forums. Aangezien dit forum speciaal bedoeld is voor Nederlandse gebruikers, is het makkelijker voor de gebruikers om u te helpen als u uw berichten in het Nederlands plaatst. Voor vragen in het Engels kunt u terecht op de Engelse forums, deze zijn te bereiken door op de taal selectie knop te klikken rechts bovenin uw scherm, naast het Sony logo.
Met vriendelijke groet,
-Tycho-
Forum Moderator
hi, next to Sony I see now UK logo. does this mean I don't have to do anything?
thanks
Hi HowLiu
The a99 does support UHS-I cards, but you'll need to use something like an EyeFi SD card to get wifi functionality.
I'm not sure about the intervalometer. There should be a way to get this via mini USB, but I'm not sure about the MX2, which may have some connectivity issues when used with the a99. Maybe ask on a DP forum?
Mick
