I have bought a Sony HDR-CX105E videocamera a long time ago. Now I'm planning to buy a Sony Alpha SLT-A55 camera too. They do not have the same batteries, but they are both in the NP-series of batteries. Will they work together? The two batteries are NP-FW50 and the NP-FH70
Thanks!
Hello at1145 - Welcome to the Sony Forums
Unfortunately, even though they are from the same series of batteries, they will have different dimensions and therefore your camcorder battery will not be compatible with your intended camera. If you take a look at the two batteries .....
..... you will see that the NP-FH70 (right) is far thicker than the NP-FW50 (left).
Having said all of this, once you have your new camera I would suggest shopping around online as you should be able to find a good deal on spare batteries for either device :smileyhappy:.
Thanks,
Simon
Thanks,
Simon
Ok then:smileyhappy:
Thanks for very fast answer! :smileygrin:
