Hi folks, i have a sony a390 its a year old, i think i need a new battery, but i looked up the same one which is infolithium h actiforce 6.8v 870mah, it says that is for a camcorder. can anybody tell me which battery to buy and where thank you very much. carol erskine
Hi Carol,
You need a NP-FH50 which is used in several Sony Cameras and Camcorders.
You can get it from Sony Direct: -
http://www.sony.co.uk/product/dcc-batteries---chargers/np-fh50#/Overview
Your local Sony Centre and from other Photographic shops like Jessops and online vendors: -
http://www.amazon.co.uk/Sony-NP-FH50-Infolithium-Camcorder-Battery/dp/B000NJ0OHW
Just make sure you are buying a genuine Sony battery.
Thank you very much for your reply, it was very helpful as i was not aware that the battery was used in several sony products. thank you again for your help. carol
