BC-TRW vs BC-QM1 Battery Charger
digitalkl
Am looking for a charger for the NP-FW50 batteries and came uopn these two.
I wonder what is the difference between these two other than QM1 is able to charge other types of battery besides NP-FW50
Also is BC-TRW a rapid charger like QM1?
Thank you so much for your inputs
Tags (2)
1 REPLY 1
Bieomax
Pretty much the BC-TRW is for one type of battery - InfoLITHIUM
NP-FW50 (W type?A7(r)/Nex/A33/a55)
the BC-QM1 is capable of lots of types of sony batterys
the BC-TRW is marketed on other reputable sites as a fast charger also
I notice that these newer chargers have the option to be plugged in via USB to charge, of which i'm a little jealous of since my A57/A33 & Nex chargers are all just wall socket.
