Somehow the mirror inside my camera is broken, can this be replaced?
I believe there may also be another problem with this kind of area as my photots come out slightly off centre.
Any help appreciated.
Thankyou
Siobhan
Hi Siobhan, welcome to the Sony Forums
The mirror is replaceable, and you can get the sensor re-aligned at the same time.
If it's under a year old you could check and see what is possible under warranty using Sony's warranty repair service: http://www.sony.co.uk/support/en/repair
If you're paying for a repair it's sometimes worth checking out a high street camera store, as they usually have decent repair centres.
Mick
