Hi, rather out of the blue I have started getting poor, grainy photo`s from my a55, any suggestions would be a help.
Andy
Hi Andy
Is this even in daylight / good light levels? Have you tried a reset, to rule out this being due to a camera setting?
If you can explain a little more about how you're using the camera (manual/auto, settings etc) I might be able to offer some advice
Mick
Hi Mick,
many thanks for your reply. Sony got back to me on this. The good news is that the problem appears to have gone:smileyhappy:. I cannot say that any one thing sorted it, as I did several resets and cleans. I ended up looking at the mirror through a magnifying glass and spotted a few specks on the edges which would not move with a blower, I removed with a cotton bud!!!!:smileyplain:. Tested it and seems to be ok.
Regards
Andy
