Is the 16mm f2.8 Pancake lens for NEX cameras discontinued? I ordered and paid for this lens and the wide-angle converter back in April this year, the converter shipped quickly, but I still haven't received the 16mm lens that is needed to use it.
I noticed today that the 16m is no longer listed on the Sony shop list of available lenses - is a suitable replacement that will working with the adapter coming any time soon, or should I cancel my order and get a refund on the never-used converter?
Hi Chrisvs12, welcome to the Sony Forums
If you ordered the lens in April there is definitely a problem with delivery!
As you noticed, the lens is out of stock in the Sony online store and may be discontinued, as it's described as a 'previous model' : http://www.sony.co.uk/product/ddl-nex-5-nex-3-lenses-and-a-mount-adaptor/sel-16f28/tab/technicalspec...
I would contact Sony customer services and raise the issue with the guys there. You'll find the contact details on this page: http://www.sony.co.uk/support/en/contacts/dime
Mick
