I have a DSC-W170 Cybershot and I would like to know a way to make it work taking video much more than the 10 minutes it has programed. Any body has experience on this?
Tito2013
Hi Tito, welcome to the Sony Forums
You may be running into the maximum file size permitted under the FAT32 card format the camera uses. One workaround is to shoot slightly lower resolution video, which will allow you to shoot for longer before the file maxes out.
There was a thread on this a while ago which may be of interest: https://www.sony.co.uk/discussions/message/810871#810871
Mick
Mick
