Nex 7
stdunne57
Nex 7
Can anybody tell me if the Nex 7 is getting discontinued before i buy one ??
blaireau_photo
Hello stdunne57 :slight_smile:
With any electronics manufacturer, there is no preset length of time that will elapse before a product becomes 'discontinued' and it usually depends upon the amount of time it takes to release an updated model. Having said all of this, once a camera does fall into this category, Sony still supports the previous version. For example, any software updates are published on the main support site for the camera i.e. the NEX-7 support page can be found here:
http://www.sony.co.uk/support/en/product/NEX-7
Thanks,
Simon
2 REPLIES 2
blaireau_photo
Thanks,
Simon
profile.country.pl_PL.title
druczek
Message was edited by: druczek
