I can move pic to editing area...but only functions above the line work...not below??
Hi there
What are you trying to edit them on? (Laptop / PC / Phone / Tablet)
Have you tried uninstalling then reinstalling?
Also can you elaborate a bit more when you say "but only funcions above the line work."
Which line?
This is from the Playmemories Help:
"PlayMemories Home" is loaded with many different functions for editing photos.
Hope this helps.
Hi...thanks...the "line"....when I try to edit...there are 3 or 4 options which I can use...there is a horizontal line below which are many more options which are not "Live" ian
Hi again
I've just had a look at my PlayMemories and reached this screen for editing photos:
I can see the options below the line, but can't recreate the problem you're having.
I assume the file is compatible / undamaged?
I don't have a quick fix for you apart from perhaps trying the uninstall / reinstall I'm afraid.
