PlayMemories Home
Patriot20001
PlayMemories Home
Hi, being new to the fantastic sony camera etc I installed SOny Play memories home.
that itself is amazing as all my pics going back to 2004 are catalogued properly. howver my video files from old cameras are not showing in the calendar?~ any ideas ?? thanks in a hopeful advance
1 REPLY 1
blaireau_photo
Hello Patriot20001 - Welcome to the Sony Forums :slight_smile:
When you set up the PlayMemories Home software, have you included the folder that contains your videos on your computer. Using the import function, you should be able to specify the location of your existing videos so that they can be included in the PlayMemories media library.
Thanks,
Simon
