Hi can you tell me if it is possible to use pro-capture on the Sony A1 ii using the Sony commander. It would mean I didn't have to wait with my finger on the camera trigger for a bird to fly from a perch, for instance. I could press the commander trigger instead.
Thanks
Hi @kevinE, yes you can remotely control your camera using the Creator's app. You can either use a smartphone: https://helpguide.sony.net/ilc/2440/v1/en/contents/201h_use_smartphone_as_remote.html Or you can use a computer: https://helpguide.sony.net/ilc/2440/v1/en/contents/0903_pc_remote_function.html You can also use this link to learn more about the Creator's app and how to use it with your camera: https://helpguide.sony.net/di-app/ca/v1/en/index.html
