Hi looking for advice on a good remote control for an a37 thanks
Hello Madguzzler - Welcome to the Sony Forums
Looking at the A37 compatible devices page here:
http://www.sony.co.uk/support/en/product/SLT-A37/compatibility
There are two remotes listed that are compatible, however they are both wired options. The RM-S1AM which is 0.5m in length and the RM-L1AM which is 5.0m.
If you are looking for something wireless, the official Sony wireless controller will not work with this camera. Hama have a third-party option called the SO-1 but there is again conflicting information online about compatibility so I would suggest visiting the product page on their website and contacting them directly about this:
http://uk.hama.com/005350/hama-so-1-remote-control-release-
Thanks,
Simon
Thanks,
Simon
