Sensor scratch? Sony a6000
profile.country.GR.title
wil-1275
Hi
i was browning the sensor.
while looking at the sensor under a certain angle I spotted 2-3 little spots , does any one knows if are those scratches?
thanx
4 REPLIES 4
IamNic
Hi @wil-1275,
it could be anything (dirt, water residue...). It is impossible for anyone to judge without having a detailed photo of the spots.
- Nic
wil-1275
thanks for your reply
I should have mention that i have never done any wet cleaning. Only by blower cleaning and never outdoors.
I tried to take a photo but it doesn t show on the photo.
It s like the nose of a pin and i can see it only in certain angle and only in lamp light othewise i can t see it
wil-1275
image.jpegimage.jpeg. Here are two photos
wil-1275
One should be on the right too the corner down and the two others on the left in the middle.
