SLT a77V - Contraversial set-up in installing PMB or PMH
ChilliMech
Running the SLT a77V software 'Set-up' on my computer (Win XP Pro SP3) up to the point of installing Picture Motion Browser, you are then confronted with another web page advising you to install Play Memories Home - which I choose and in doing so replaced PMB.  Now, on visiting the Sony site for the SLT a77V for any updates, I noticed the instructions on using PMB. I do not own a Play Station, so my question is - Do I now revert back to re-installing PMB, or use PMH ? as there is no advice as to which you should use, should you not own a Play Station. I have not attempted to use PMH.
Tags (4)
blaireau_photo
Hello ChilliMech - Welcome to the Sony Forums :slight_smile:
PlayMemories Home is the latest version of the software bundled with Sony cameras and it is designed to be used on a computer. PlayMemories Studio is a version of the software designed to run on a Playstation 3. Therefore, you can install PlayMemories Home safe in the knowledge that it has been designed to work on your computer - I can understand why there may be some confusion though as there is no immediate indication in the software title about the product being designed specifically for a PC or games console.
Thanks,
Simon
2 REPLIES 2
blaireau_photo
Thanks,
Simon
ChilliMech
Hi Simon
Thanks for the answer. I can now sleep better at night !  It would be nice if the infomation was implemented into the software so that people do not get confused.
Thanks again :slight_smile:
CM
