Is it possible to upgrade a NEX5D smart terminal to a smart terminal 2 that will allow a tru finder viewer to be attached to the camera?
Hello again
Unfortunately it is not possible to upgrade the existing Smart Terminal as the Tru-Finder viewer is only compatible with the NEX-5n.
There is some more information available about compatibility on the support site which can be found here:
http://www.sony.co.uk/product/dac-nex-accessories/fda-ev1s
Thanks,
Simon
Hello Baggies1952 - Welcome to the Sony Forums
I am going to look into this with a contact of mine - I will let you know when I hear back.
Thanks,
Simon
Hello again
Thanks,
Simon
Thanks for the clarification on this. Would be nice to have this fixed in the future tho. Although, the current setup works good I think.
