SNAP cable for Alpha 6500?
Tyseren
I'm wondering if someone can help please?  I want to use my 6500 with the Star Adventurer mount (https://www.firstlightoptics.com/skywatcher-star-adventurer/skywatcher-star-adventurer.html) for widefield time lapse astrophotography.  Skywatcher sells cables for camera control (https://www.firstlightoptics.com/skywatcher-star-adventurer/shutter-release-cable-for-sky-watcher-al...) but the one for Sony cameras has a different fitting to that required by the 6500.  Can anyone recommend a source of the right cable please?
Thanks
Helen
Blencogo
2 REPLIES 2
Blencogo
Tyseren
Brilliant!  Many thanks for the link, I'll get it ordered. I'll post some pictures if I get competent doing the time lapses!
Helen
