Sony DSCW630 Digital Camera battery charging
iggy29
Can the battery be charged without having to remove it each time from the camera?
If not Sony are way behind the competition and I am VERY disappointed with the purchase!
Iggy
Message was edited by: iggy29
blaireau_photo
Hello iggy29 - Welcome to the Sony Forums :slight_smile:
This camera has been designed without a power socket in the camera itself which means that the only method of recharging is to use the supplied battery charger. One partial solution may be to purchase a spare battery so that you can always have one in the camera while the other charges.
Thanks,
Simon
1 REPLY 1
blaireau_photo
Thanks,
Simon
