- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
2015 Bravia Android TV Issues
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Just treated myself to a KDL-43W755. I'm probably doing something wrong/silly, but is there a way to pre-select TV programmes on the Guide, so the set swaps channels for me automatically on some kind of 'timer'?
Also, is there a way to go up and down a page on the programme Guide?
My old KDL-40V2500 would happily do both of these basic functions, and I'm a bit disappointed tbh.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Edit: Home screen issues have been resolved, perhaps it was a server-side issue? Also, having had more time in front of the screen since the update, I've noticed that the SD picture quality seems better / smoother -- I'm presuming this is due to the improvements to picture quality mentioned in the update notes.
I'm also experiencing a number of home screen related issues after installing today's update. The home screen appeared to restart numerous times after the initial post-installation boot but thankfully now appears stable, however, there is now a constant, unsuccessful attempt to load recommendations and the featured app section has disappeared.
In addition, the general performance of the home screen feels worse when overlayed over input source video (even more so than before the update); opening an app or the system settings and returning via the 'back' button speeds things up, likely due to the static background image that replaces the video. Finally, whilst I can't say for certain whether boot times have increased, the boot animation seems much more sluggish.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Anyone with a Playbar got DD5.1 working through hdmi? Loads of old Sony TVs supported that so I hope they haven't removed that feature with the 2015 TVs.
Edit: never mind, was a setting on ps4.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I too also can't find any kind of reminder feature nor does it currently have the option to page up and down. I'm sure it will be released in a future firmware update. Why can't they build something and need not have any need to update it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
