2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
Sdroid
Installing now so it will take a while until I know. I have the 65x8509c
Brigante01
Sure if you could check later that would be great!
Swedish here as well by the way but living in the UK so I have to wait lol!!
profile.country.BG.title
kijelmi81
 I update also! Bulgaria, KDL-43W809C.
Teknixjack
I have sent my credit card company a letter stating that Sony have sold
something not fit for purpose and have said they will not give me a refund.
Will keep you all posted as to the outcome. Glad watchdog are on it will
just give me that much more backup and clout to get my money back from this
lying company
Drpepper970
I have a UK spec TV (or so I thought as I bought direct from Sony on pre order) and I'm currently installing an update that wasn't available yesterday. Should I be worried?!
Brigante01
If anyone's got a KD(43 or 49)X830C and can update could you check Settings - External Inputs - HDMI Signal Format - Enhanced (this one should would be a new setting)
Thanks!!
Brigante01
@Drpepper970 are you in the UK?
MrLizard
I'm in the UK, bought my 49X8305C in August and it is now downloading an firmware update!
Brigante01
Hmm mine is updating now as well!? I'm in the UK.
MrLizard
So, I wonder if our TVs are about to get bricked!  I have a horrible feeling that someone at Sony has pushed the update to the UK when maybe they shouldn't have!
