@Twobins so you've returned it and don't have it anymore? why do you care how long it takes?
I returned it because I was worried about being stuck with something that didn't work as I wanted it to. I only had 90 days to decide and returned it about three weeks ago to JL on the 89th day. ( Sony weren't able to give me a date for the next software update) I liked the look of the TV and the 43inch is perfect for my room. The only other 4K at that size is the LG - but its nice to have Kodi available on the TV rather than a under tv box. If Sony are able to sort out what needs sorting out, I'll re purchase the tv. Im currently making do with an old 32 inch flat screen Toshiba that is well past its sell by date, so I do have an interest still.
The update certainly has improved the response times when changing channels and menu's but I do have one issue that worries me which I'd be interested to hear if others have experienced.
The TV (55X8509C) is wall mounted and for the first 45mins to an hour the tv "Crackles" as it heats up. After that the base of the TV gets quite hot (not too hot to touch but far from just warm).
It may be a normal operating temperature for this model but it's a lot warmer than I would expect or have seen before.
Any feedback is greatly appreciated.
Why does HDR look so saturated?
Where on the Base the bezel or the rear casing? I can't say ive noticed mine getting warm and I have the same model as you. I'll check properly when I'm home.
Thanks for the quick replies.
@Kevwoods12 It's at the base of the TV where the speakers are - all the way across.
@Triswillmott That's exactly it. I'm now a bit worried about safety so I'll bring it back today.
Sony 4k Android - the gift that keeps giving!
@EggDublin Good luck, hope your experience is smoother than the painfully slow experience I've endured the past 4 weeks.
