Hi there, I have noticed something since the last updated, youview has vanished from my tv it's not on the tray, and went thru the app list in settings, it's gone, my model is kd-43x8305c any help would be appreciated don't want to have to do a factory reset unless essential
Fatz
Sounds like you've updated to the EU firmware, rather than the UK one perhaps? I'd get in touch with Sony support and see if you can re-install the latest UK firmware.
An RF modulated signal via co-ax and boosters is always going to be very poor, that's not the fault of the TV.
You'd be better off with an HDMI switcher and HDMI cables from the Sky box, which are probably OK for 1080, up to about 15m in length
I occasionally get an alert - "TVdotAction has stopped" - whilst watching a feed from a non-sly satellite box.
And now for something completely different.
1. Sony makes the Xperia range of smartphones that has a reasonably large developer community. It would be good if Sony could unlock the bootloader and publish firmware source code so the developer community could help Sony's own beleaugured developer team find solutions. IMHO the Android platform is the way to go; Sony are probably not the ones to take it there.
2. Is the late delivery of a recording facility more to do with licensing issues than coding software?
Nibor99 - Please could you let me know which settings you used to get the "format:- full screen" issue sorted?
I've checked around the menu settings and couldn't see a way to do it.
Thanks.
At a complete guess, I'd say the default of Auto causes the TV to monitor the current picture and if it shows black bars it will trigger the screen mode to change (like 4:3 content being stretched to 16:9), hence the constant popups. I think I set mine to Wide and haven't seen it popup much since.
Ahh right I had it set up with a dns proxy to access American Netflix maybe that confused the update then
