well it looks like Sony still have not bothered to fix the Amazon Video 5.1 issue, this is getting ridiculous now I wish they would say why they won't fix it especially as the US have had it working since last Summer.
If they won't fix it, maybe they can give me a 4K Fire TV to make up for them not caring
Been waiting for this HD recording for an age, now its here, i realise that the KDL-43W756C doesnt have twin tuner.
***** what a waste of time. This set is so retarded. Looks like I'll be hanging on to my 5 year old HDR-FOX T2 Freeview+ for a good few years longer.
So very dissapointed. my fault. should have returned it when I had the moral right, never again SONY.
@andipr wrote:Well that was a bit of a disappointing update - I've been waiting for PIP / PAP for a long time and can't get it to work.
I don't use digital tuners or youview - all of my TV is via Sky HD box, so I can't test the PIP/PAP there, but does anyone how to PIP/PAP two HDMI sources? I was expecting to do this but when using the action button I try and select the second source and it is greyed out in the list of source options.
And is there anyway to cast from a device in one window and have another window display a HDMI source?
PIP/PAP was working ok for me. I had my PS4 working through HDMI 4 (ARC), clicked 'action menu' and the selceted watch TV (I think) and it split my screen. I only had sound from the PS4 though and could figure a way of switching between them.
Is the incompatibility between HDD recording and YouView permanent, or are there plans to address this in the future?
I haven't actually tried it but in some of the official blurb I read yesterday it said USB stick would work for recording as long as it is FAT32 format. If I stumble across the blurb again I will post it on here.
Installed the new update last night - was really looking forward to HDD functionality and it seems to work fine. I'm really disappointed though. I assumed HDD record would come with pause/rewind live TV. As far as i can tell it doesn't. Pretty gutted as I was hoping to get rid of my STB. Serves me right for assuming I guess.
If you turn off youview to enable hdd recording which by the way is a joke as youview should not effect recording will i then be stuck with navigating through the tv guide 1 channel at a time when it should jump a page at a time like youview can?
@fedidan Yes, Isnt it awful?
It seems to be litterally LESS useful than plugging a standalone VCR into the tv. At least with that I can watch something else during a record.
Not even a pause feature on a single tuner TV is terrible (my model). And probably now theyre not even legally obliged to make it any better as all the advertised features box's have been ticked.
Fully expect these tv's to be written off with regards to support updates from now on. Sony will just want to draw a line under them.
Hi All,
I have come tot he end of my rope with this TV and I am now looking to return it. I have raised a complaint via the Resolver website which tracks your complaints in a case file and helps you escalate if you are not getting answers. In my complaint I have included a link to this forum with all the evidence Currys will ever need. Meanwhile Im trying to decide what to replace it with, I may add a little more on and buy something better. So far this is the set that has really caught my eye:
I used it in thr store and its a joy to look at and navigate. The picture is stunning and you can use the magic remote as a kind of wiimote pointer to select the options you want. Web OS was smooth and fast, and looks waaaay better than what we currently have.
I'll let you know how I get on with the complaint. I have already mentioned that I KNOW they are aware of the issues and that I KNOW they have already taken sets back, so we shall see.
