Делитесь своим опытом!
Take it back and get a refund as soon as you can.
You will have to live with these issues until you get a new TV. I have for 13 months now.
I wake up during the night to find my TV turning it's self on & off without the LED light ever coming on. Soon as I push the power button on the remote it freezes the TV.
http://handforgedvideo.com/portfolio/pattern-help-text/
Advanced video-setup - framing (center of the screen).
https://postimg.org/gallery/1cqx6igpu/
this pictures shows 3D mode resolution issues very clear. 3D mode you should switch on in disc menu. Is it possible to fix this issue in next firmware?
Thank god for seeing this!!! I thought I was going mad and the only one having this issue. I have the BT UHD Youview box (I work for BT) and I have loads of video stutter but never audio. I have had the TV changed (4K 49" Android TV) and it made no difference. I have also had BT in to change the UHD box and again no difference! I opened a case with Sony UK and they flatly refuse to acknowledge there is an issue even though I have sent them video camera footage of the stuttering. My friend has the same BT UHD box on a non android Sony 4K TV and it works a charm. I think I'm stuck. Sony UK refuse to give me a refund and the Sony Centre shop I bought it from refuse also so unless I go down the small claims court route I'm stuck. To top it off I also get random reboots of the TV and the remote control is sometimes unresponsive. All in all pretty disgusted with Sony.
This may have nothing to do with the bt uhd box issue but I posted a couple of weeks back that I couldn't get any usb device to play any tv recordings without a noticeable stutter. I haven't found anyone else with the same usb tv recordings issue but the two may be linked. I really hope there's a solution to the bt box issue as I suspect it'll resolve whatever it is causing the stutter I'm getting.
