A1 OLED TV
Bill00
A1 OLED TV
Why is the OPERA TV internet browser  not preloaded into the A1(see detailed specification ),a $4000 TV,when it is standard on other Sony Andoid TV's?
Is this some sort of US  competiton enforcement  agency issue,which will not apply to the UK ?
After 10  years  of  waiting for  a credible Pixel  Plus processed  CRT replacement, I would just like to switch the thing on and use  it  straight out  of  the box.
10 REPLIES 10
Anonymous
Not applicable
Hi @gilfeath
Apologies for the delay in responding, seem's your question got missed - probably because this thread was marked as 'resolved'.
Anyway, onto your questions:
1 - Pre-installed Apps
Unfortuately the pre-installed apps cannot be removed or hidden.
2 - Home Screen Suggestions:
These can indeed be hidden.  Simply goto [HOME] > Settings > Home Screen (system preferences) > Recommendations row >   And uncheck each option by pressing the [OK] button on the remote control
3 - 3rd Party app to do 1 and 2
Answer is no
4 - USB HDD Recording
You can record TV shows from the TV to a USB hard drive.  You must register the hard drive to the TV firstly.  For more information, see : HERE
Hopefully this helps
