I have a Sony Bravia 55xe8396b TV bought just over a year ago and suddenly seem to be having a major issue with the WiFi on it.
Since getting the TV we've had multiple occasions where the WiFi has dropped and we've been unable to reconnect at the time, however usually a few days later the issue has sorted itself and we've been able to continue as usual. About 4 months ago, I reset the internet connection with the TV to the WPS setting and since then we've had no problems at all.
Until Thursday, I went to watch Netflix and got a message to say the TV wasn't connected to the internet. When I went back to the home screen and to the settings, I noticed the WiFi button was in the off position. I tried to turn it back on but it keeps flicking straight back to the off position.
I'm now in the process of factory resetting the TV to see if that helps, but for a TV a little over a year old, we didn't anticipate having these problems. A quick google search shows that a lot of people have issues with the internet connection on Sony TVs, so I think this might be our last one if we can't rectify the issue.
Has anyone else had this same issue or something similar? I'm not sure what else to try!
@glynnl4umb ha scritto:
Sounds about right for when problem started for me. Are you listening, Sony?
It doesn't seem that Sony is the publisher of Android Web view component, am i right?
I pay for my tv as much as you do, sorry
Don't worry I'm used to and I was curt my self (didn't even know this word before btw
If you get this message while still connected it could be due to router briefly disconnecting the line but non enough to consume the buffer you have.... You may want to check which kind of router you have and try disabling IPv6 if it is possible on it...
