I have a 55 xe9005 which is connected to a yamaha rx-v371 av receiver via arc. This all works fine, but the volume up and down is a bit laggy, especially as I generally increase or decrease the volume by 5 steps at a time (from -40dB down to -42.5dB)
Is there a way so that pressing the volume down once, sends the down command several times? I wouldn't might the slight lag if I have to press it less
Hi there,
Welcome to the forum.
We'll check this and let you know what information we find. Also, maybe some other members will have some experience with this and can offer some advice.
Best wishes,
Ed
Hi Wardy277,
Do you control the volume using the TV's remote control or the receiver's remote control?
Cheers,
The_Black_Rose
Thanks for the reply. I use the TV remote to control the reviewers volume.
Hi Wardy277,
I'm no so sure that this function will even be supported to be honest.
Cheers,
The_Black_Rose
