New Sony xf90 audio issues
Admurray
Hope someone can help.
Just got a new Sony XF90 65 and it's awesome but I have one slight niggle.  Everytime I turn the TV on it defaults to enable the audio system, not the internal TV speakers.  I have gone into the settings to select TV speakers but then when I turn off and switch it back on it again reverts to the external audio system.   I have tried connecting via optical and hdmi but no luck.  It's a bit annoying to have to switch the setting everytime I turn the TV on.  Does anyone have any advise please?  Thanks.
LightFoot
Specialist
Hi @Admurray
What have you got the Audio System prioritisation set to? I would try setting it to off ... Home -> Settings-> Sound. While you are in that menu have a look at the Home theatre control etc.
2 REPLIES 2
LightFoot
Specialist
Hi @Admurray
Admurray
Star.  That fixed it, I was not aware of additional sound settings outside of the core action menu sound options.  All good now.  Thanks!
