No sound from IRC ACR SOUND BAR after connecting IR Blaster to control BT BOX on my new 55AG8
johjohns28
Hi folks - again,
Having decided to try the IR Blaster to control my BT box with the hand set I can indeed change the channels etc however in the process I have lost the sound from my sound bar. This is connected via an HDMI lead to the ACR port. I have checked the lead and it is OK. If I go to Settings>Speakers I can get sound on the TV speakers but not on Audio System.
Can anyone suggest a solution? Thanks - John
4 REPLIES 4
johjohns28
Please ignore the typo IRC in Subject Line.
johjohns28
Please ignore both posts. I’ve fixed it!!!
Mountsbay_boy
Hi
I have the same problem, how did you fix it?  Thanks in advance
johjohns28
Sorry I have not solved it! The IR Blaster has stayed in the drawer.
Sent from my iPad
