Hello. I need too prevent my son from using the tv. Instead of looking for a job. So can I put a pin on it to prevent him from using the TV at all. If I can how do I do it?
Hi there,
So I can look into this for you, can you let us know the full model number of your TV?
Best wishes,
Sean Mc
Hello Sean
The model number is KD-55xe8396
Sorry it took so long too reply
Hi Ingchr1970,
I've just had a look into the manual, I believe you can set up a pin for almost everything.
I recommend that you check this link: https://bit.ly/2RYD3QX
Cheers,
The_Black_Rose
