Problem with kd49xg8196 sony Bravia 5.1 sound
antinoa76
Hi. I have recently bought a Sony Bravia Android TV kd49xg8196. I connect the tv  with an optical cable to my home theater but I can't get any 5.1 Dolby sound when I watch Netflix. My Netflix account has the option to stream ultra HD 5.1 so the account is not my issue. When I connect my tv box with the same optical cable to my home theater everything works great. So I am sure that the problem isn't neither my home theater nor my cable. Can someone tell me the right settings so I can make it work?
Thanks in advance
1 REPLY 1
profile.country.HR.title
kinggo01
did you set it to external audio (audio system)? Also, try different options under audio output although Auto 1 should be fine.
