Problems with Spotify connect and Sony Android TV
profile.country.DK.title
SonyCPH
With Android 7 Spotify was allways running in the background, allowing my phone to find and stream to Spotify connect.
With Android 8 the TV shuts down Spotify connect when using other apps. That means that only Chromecast streaming is available for streaming music.
Any suggestions on how to install Spotify connect as a Service or any other suggestions on how to keep Spotify running
2 REPLIES 2
profile.country.AT.title
Kuschelmonschter
Hero
Yes. I made the same experience. Oreo improves performance quite a bit by killing/suspending background apps much more often than Nougat in order to free up resources.
SonyCPH
Solved it by using the app "Launch on boot"
This autostarts any selected app.
The Spotify connect service isn't killed/suspended even if I stress the OS heavily 😃
Spotify has however introduced a new issue:
When starting the Spotify app, autologon is disabled, so you have to tap ok to start the app, so whenever I turn on my TV, it will be stuck on the Spotify login screen awaiting a button press.
