A recent update seems to have stopped the bbc iPlayer from playing UHD programmes. They worked fine before the update late November. Anyone else had similar issues and found a fix ?
happy days
Yes, mine came back yesterday evening as well.
I cannot find what I posted, so I don't know what you're referring to either!
Oh - hang on, found it. Basically, if your reception didn't go down for 2 months, then your signal didn't/doesn't come from the Bilsdale transmitter in NE England (which was destroyed by fire in August) and so you weren't affected, you lucky thing!
Hey, glad to hear that the issue has been resolved for you, thank you for updating the thread.
