Sony X90K Turn On/Off Sound When Switching On From Plug Socket
MetalQueen87
Hello,
I very recently purchased a Sony X90K 75inch tv and what I've noticed is when I switch the TV on from the plug mains socket, after about 15secs, the TV makes a clicking sound as if it's turning on then turning off.
When I switch the tv on with the remote it clicks again when turning on and then again when turning off, this to me is normal, my previous Sony 75 900e did this but not when turning on from the mains.
I've attached a video I took to show what I mean.
Is this tv behaving how it should when turning on from the mains socket with the turning on/off sound before it's turned on with the remote? Or do I have a faulty unit?
Advice would be much appreciated.https://www.youtube.com/shorts/VKUBBDWSYE4
1 REPLY 1
Elodin
Moderator
Hey @MetalQueen87, this is normal and it is explained here. I hope this helps
