USB 3.0 GIGABIT ADAPTER
D-Law81
As the ethernet port on sony TV only do upto 100 mbps if I was to put a USB 3.0 gigabit ETHERNET ADAPTER into sony x94j usb 3 port and used a tp link gigabit ethernet adapter would it work.????
96 REPLIES 96
royabrown2
Hero
@G73MCT
If you got it off Amazon, returns are easy and straightforward.
G73MCT
Thanks for that did not realise Amazon would allow returns unless faulty.
G73MCT
Big thanks to @LightFoot and @royabrown2 for your advice, UGREEN has been sent back to Amazon today and UE300 has been ordered.
LightFoot
Specialist
Hi @G73MCT   Not just Amazon, ALL online Retailers have to accept no fault returns. It is just some make it easier for customers 😀 It is called Distance Selling.
https://www.gov.uk/accepting-returns-and-giving-refunds
G73MCT
Well my TP-Link UE300 arrived today and all good.
Using wifi I would get 312 Mbps down and 264 Mbps up now get 939 Mbps down and 911 Mbps up.
what a big difference 😀
AlexKid
Hi, I have a K-85XR90 and the TP-Link UE300. The USB Ethernet Adapter worked out of the Box. The problem is that I can not switch on the TV anymore when the Adapter is pluged in. I have to disconnect power and after connecting power again I have to press the "ON" button in remote for ~10s to restart the TV. I also tried the developer USB settings with same result.
Any ideas?
LightFoot
Specialist
Hi @AlexKid
The firmware on these Bravia 9 TVs is completely new, perhaps you have discovered that the UE300 is no longer compatible. The UE300 is now an old model so it may be you need a newer model. Useful information for the community.
I take it you have tried all the USB ports.
What amazes me, that in 2024 Sony are not using 1 Gb network cards. It must be difficult to source old 100 Mbps chips! I take it you have tested the native network Ethernet speed?
AlexKid
you are right. For the newest Bravia 9 Series we need a newer USB3 Ethernet Adapter. I searched a while and ordered this one:
Ugreen LAN Adapter
I tested it for one week now without any problems
profile.country.SG.title
cashkey1
hi guys.
i have a xbr-85z9k (year 2022 model)
and also a xbr-65a95k (year 2023 model)
i have bought two different models of the tp-link usb "A" Gigabit adapter's.
one is the "UE300" and the other is "UE330 with 3 usb 3.0 ports in it"
i have tested both model's successfully.
Hitting speeds way way above the inbuilt sony ethernet port.
thank you all for this info.
cheers!!
cashkey1
IMG_20240819_212309.jpgIMG20240815191425.jpgScreenshot_2024-08-19-21-23-26-67_99c04817c0de5652397fc8b56c3b3817.jpgIMG20240818110416.jpg
