Xf9005 netflix problems with Dolby vision
Bastosnf
Hi, I've just updated my xf9005 to latest version of oreo, but I still have noise in the image when watching 4k DV content with Netflix. In HD I have a clear image... Can anybody help me? Any suggestion for setting the definitions of DV?
4 REPLIES 4
Sean_Mc
Moderator
Hi there,
I'm looking into this and will update the thread when I have an answer for you.
Best wishes,
Sean
The_Black_Rose
Specialist
Hi Bastosnf ,
Did you try manually adjusting the picture settings:  https://bit.ly/2ExAsGA ?
Cheers,
The_Black_Rose
Bastosnf
Yes. Used the settings provided by Rtings. For instance with Google play
the image is excellent only with Netflix and HBO the quality is not so good
The_Black_Rose
Specialist
Hi Bastosnf ,
Could you provide us with a photo?
Cheers,
The_Black_Rose
