YouTube Connection Speed
dgl123
Entdecker
I have broadband of 49meg.
If I look at the stats for nerds on YT inbuilt app I have a connection speed of 22meg.
If i then go onto a mini pc i have connected to my TV again look at the stats I have a connection speed of 39 meg.
Where is the other 17meg going when using YT app built into the Android TV???
The issue is this loss of 17meg means full 4K does not work. However if performing through mini PC it works!
Something is sucking the other 17meg I am guessing but I cant figure out what. Annoying.
1 ANTWORT 1
Anonymous
Nicht anwendbar
Hi there,
Have you updated to the latest firmware?
Best wishes,
M
