AX53 help with extra monitor
DanHendriksen
I have recently started using the Ax53 camcorder which is great but I want to add a bigger extra monitor to sit on top of it.
I can record and see the footage in HD but it won’t show it when filming in 4K.
does anyone know why I can’t see it in 4K?
thanks
Dan
Tags (1)
2 REPLIES 2
Win_88
Specialist
Which monitor are you using? is it the CLM-FHD5?
Win_88
MikeHall721
I also use an external monitor, but when in 4K mode, there is no output to HDMI Out- only HD. The camcorder is designed that way and isn't a fault.
