Battery replacement for NP_FH40
jeffo2020
My first post.
I am loosing the  will to live! I have a DCR SR32E Handycam. It's old and needs a new battery. It takes a NP-FH40.
Sony messaging help say the only recommend the exact replacement battery, they don't seem to have a helpful cross reference list to recommend another.
Sony website only offers the NP_FV50. Their supplier EET offers NP-FH50.  I could buy the NP-FH50 but would it work.
I don't want a Chinese nock off fake or one that the camera doesn't recognise.
I would appreciate any advice
jeffo2020
I solved my problem not through Sony or its UK. supplier of replacement parts. After much research I went to Amazon. A9252 A9275 Powergiant 12v 2000mAH NMIH. This solved my problem.
9 REPLIES 9
Pascale_F
Moderator
Hi Jeff,
Welcome to the community.
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
The_Black_Rose
Specialist
Hi Jeffo2020,
I wouldn't recommend using a battery other than the one recommended by Sony.
When it comes to power, it's better to follow the manufacturer's instructions.
Cheers,
Rose
jeffo2020
 Great advice Rose, however Sony tell me this battery is no longer available. Their supplier in the uk has a subsidiary business that can offer an alternative but I will be wailing another four weeks for delivery.
There are many batteries out there some of which will not work or  be rubbish. At Sony prices I would have thought they could have maintained supply of the NP-FH40.
So much rubbish coming out of China these days. one of my favorites is 18650 li-on batteries with wild claims of 9000mah. Impossible.
I just hope my battery is ok when it finally arrives.  Jeffo.
The_Black_Rose
Specialist
Hi Jeffo,
I totally get your point. I think sometimes they have to focus more on newer products and drop the support for the old ones.
Although I really love those handycams, I had one many years ago and it was the best.
Well, I hope you'll receive the battery soon and maybe share some great footage with us here,
Cheers,
Rose
10natty90
Hi, I am currently having the same problem, did you reach a happy conclusion in the end, online all I can find is the FH50 but the battery I'm needing is the FH40 your advice would be greatly appreciated I love my little handycam none of these new ones would compare in my eyes. Thank you
jeffo2020
10natty90
Thank you, your speedy reply was greatly appreciated I will take a look online.
Angjela
did you manage to figure out if the FH50 worked for the camera or not. I am having a similar issue of not being about to find a FH40 replacement battery.
TheMaze
Unfortunately, it's only compatible with the NP-FH40
