HDR-CX450 - is there a way to send clean HDMI for live streaming?
Is there a way to send clean HDMI signal, free of screen indicators, for live-streaming?  I plan to live stream with a few HDR-CX450 cameras using an Atem Mini Pro to send to YouTube, but I can't find in the manual or menus how to toggle the indicators off  (presently showing 'Menu', 'W', 'T', record red dot and the microphone indicator).
You have to disable CTRL for HDMI in the menu:
If you do not want to display icons on the screen of the TV connected via HDMI, select - [Setup] - [ Connection], then set [CTRL FOR HDMI] to [Off].
Peter
2 REPLIES 2
Peter
That's perfect Peter - exactly what I needed.  Many thanks
