Sony FDR AX33 - Stuck UV Lens how to remove?
Hello all,
I'm wondering if anyone has the same camera as I have?
I also have the Amazon Basics UV 52MM Filter on the front to protect it from the elements, but I want to take it off to give it a clean, trouble is I'm having trouble removing it, I even brought the "Clamps" to try and budge it but it's not happening.
Any ideas?
1 REPLY 1
IamNic
Hello @RobCharles1981,
stuck filters are always unfortunate.
Have you seen how Adam Savage (you may know him from Mythbusters) removed his stuck filter?
- Nic
