xzp slowmotion resolution problem
profile.country.LT.title
luscanoo
Having a problem with my Sony xzp i bought some days ago, i'm experiencing some trouble with slowmotion (960fps) recording, the moment i start recording at slowmo, the camera resolution becomes just terrible as well as the whole filming quality(and it's not because of the lighting). I saw some simple videos on youtube with xzp slowmotion filming, and the time they switch from normal filming to slowmo, their resolution doesn't change at all. What may be the problem and solution for this?
1 REPLY 1
IamNic
Hi @luscanoo,
you definetly need a lot of light for 960fps recording.
If you don't have a lot of light accessable, the video will get very grainy.
Would you mind uploading an example video to YouTube, so I can try to evaluate what the problem is?
- Nic
